Don't run synthetic brake fluid (dot 5) in anything not meant for it.
I flushed with fresh dot 3 years ago, then added somebody's dot 4+ (dot 5.1).
If you use the brakes enough to experiance brake fade, switching from dot 3 to dot 4 will help a little bit.
If you never experiance brake fade, flushing the brakes with fresh dot3 brake fluid every-every other pad / rotor change is fine.
AIM/Yahoo Toysrme257th
Now with Turbo!
