Can i Remove my front sub frame? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2005, 09:44 AM   #1 (permalink)
View smoky723's Photo Gallery
3rd Generation Can i Remove my front sub frame?
hey guys as u now my tranny dies and my idea to replace it is to drop the front sub frame with the motor is it possible to drop the sub frame or not if not how can i get the new tranny in?
smoky723 is offline   Reply With Quote
Old 07-08-2005, 09:50 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
yes...or at least according to the shop manual.....but there's just about no way thatyou can do that without a lift though....you'll need the car about 3 feet off tje ground.
the only other way is to take the engine &tranny out from the top...otherwise, you'll have one helluva time trying to separate them from above
good luck
HaHa
Old 07-08-2005, 10:58 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
^^^ what he said there is probably no way you will be able to get the car high enough off of the ground to be able to pull the subframe with the engine and tranny. However you should be able to drop the subfram and get it out of the way then you will be able to seperate the engine and trans but will need to support the engine somehow once you get the trans out. I hope the made sense. Basically remove the subfram, the engine and trans will be supported by the upper motor mounts. At this point you need some kind of engine support, it can be an engine lift or I think there is something you could put on the inner fenders to supposrt it. At this point you should be able to remove the trans. But you are still going to have to be able to rais the car up fairly high so you can get the trans out from under the car so jsut make sure you account for that.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 07-09-2005, 03:12 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Its possible, but you need a lift and something to support the engine.
Check out the pictures in the thread below:
http://www.tt-cc.com/ratko/swap/index.html
Or yank the engine + tranny together out the top. Its not that much work to pull it out through the top.
"Skoolin' the unlearned!"
