HELP ME NOW! plz :)
Ok, heres the deal.
92 Camry
5 speed
5s-Fe
92k
I pulled my cylinder head to have some valve work done, Competition valves and polished ports.
Got my head back months ago, Installed the head Set timing douple checked with a tech at work. Checked the distributor to make sure its lined up with #1 piston at TDC Compression The thing just wonts start. The starter turns, but it sounds as if there is no compression. I am 95% everything is Connected right. I hear some backfiring like every 5 seconds when the starter is turning. I have access to a lift, and any tool imaginable. WTF!!!???!!!???
All suggestion are appreciated.
Also is the 92 5s-Fe an interferance engine?
