Originally Posted by greeneclipse
about those seals you mentioned (crank, oil, cam)....do i need a tool for these or do they just pop right out? and do i need any kind of adhesive/sealant to put them back on?
NO you do not need any special tools. Just a small flat bladed screwdriver will work fine. NO you do not need any specials adhesives or sealants, but would be helpful to have seal installer set.
[QUOTE]also a few more questions....(1)someone told me that i need a crank pulley removal tool...is this necessary?[QUOTE]
You do not have to have a pulley remover, but it will make it easier maybe. If you have to very large screwdrivers or prybars you can put them on the back side of the pulley and remove it by alternating pressure from side to side.
[QUOTE] (2) do i have to remove the camshaft sprockets/gears to get the timing belt off, or can i just slip it off after i remove the tensioner.[QUOTE]
You do not have to remove the cam gears or crank sprocket to remove the belt itselbut, you will need to remove them in order to change out the seals. The cam gears are held on with bolts buth e crank sprocket jsut slides over hte end of the crankshaft. A large pair of channel locks should fit over the cam gears so you can hold them in place while removing the bolts. Just be careful not to damage the cam gears.
[QUOTE](3)when i have the belt off, if one of the pulleys moves out of position (away from the marks) can i just turn it any which way to get it lined up again?[QUOTE]
If for some reason one of the cams or crank move you can turn them without causing any damage. The 1MZ engine is a non-interference engine as someone has already stated. Just line the marks up when you are ready to install the belt again and you should be good to go.
sorry for so many questions, but i've never changed the t-belt on an interference type motor like this one.
thanks again for your help
As stated above the 1MZ is an non-interference engine so you do not have to worry about any problems associated with that.
I would also reccomend that you try to download the Camry repair manual that is available on here. I know it is not for the 99 year model but the information concerning the engine will be the same regardless of year model when it comes to the timing belt information.
I hope this helps you and if you have any more questions please fell free to ask.
Well I screwed up the whole quoting part of this but hopefully you can read it all and it will be helpful. I have never tried breaking down the original post and answering so my bad on that.
