Originally Posted by Den
Second
I just noticed my e brake signal on the dash will go on by itself sometimes
when I wasn't pulling it. Does any of your have the same situation??
Please reply me and share your solution/situation~!
Forth
I wanna buy a set of 16-17" rims. Any suggestions, like brand, prices ?? I am looking for performance more than comfortable( i don't care ). Last question, light weighted rim seems better, but how much are those??
For the ebrake signal being on, check your brake fluid and make sure it's topped off. Even if it's in the acceptable range on the reservoir, top it off with fresh fluid. If that fixes it, you should check to see if you have a leak somewhere or make sure that your pads aren't totally worn out.
I'm not sure what you mean by a performance rim, but it has to be light. As for comfort, 16" would probably be more comfortable than 17" rims, but tires would probably make more of a difference. I have no suggestions on brands as you first have to start with a budget which you didn't list. If you only have $1000, don't even bother looking at the better brands.
