Removing screw and replacing screw on bottom of damper cylinder is what I should have done to remove glove compartment door at that time. Lack of this infomation cause the damper cylinder to become detached at the top end when trying to remove gloce compartment door without finding any instruction in the Toyota manual on how to remove door. Again how do I reattach damper cylinder at the top? Is there a part inbetween two holes on side ofcylinder and small tab holding wire harness? Could that part fall down out of sight.
Reason: To get help and provide additional information
