Trunk does not pop open - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2005, 01:56 PM   #1 (permalink)
Registered User
View qprint's Photo Gallery
When opening the trunk using the remote, the lid opens 1 inch only. I've seen other Camry's pop all the way open. Is there an adjustment I can make or am I looking to find the lid binding somewhere ?
qprint is offline   Reply With Quote
Old 07-13-2005, 02:26 PM   #2 (permalink)
t^3
Formerly Mad Scientist
View t^3's Photo Gallery
One thing I've done is to clean the contact areas where the trunk lid meets the body. That seemed to make things better. However, you shouldn't have to adjust anything, unless something has messed up your torsion bar. There are two other settings you can set it to, but I haven't actually taken the time to find it myself. You'll have to take out enough of the trim in the trunk to get to it.
t^3 is offline   Reply With Quote
Old 07-13-2005, 03:43 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
shove a brick or block of wood between the 2 torsion bars -- the 2 small bars that run across near where teh boot light is, the mroe you pry them apar the harder your boot will smack someone in the chin.
terrastrife is offline   Reply With Quote
Old 07-13-2005, 04:49 PM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
it was designed to just open a bit, unless u alter it
it is not like other cars, i.e. altima 2002
skewe is offline   Reply With Quote
Old 07-13-2005, 07:36 PM   #5 (permalink)
some ppl have ones that open a bit, some have ones that pop all the way.. its pretty random =\
Old 07-13-2005, 08:14 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Do you see any slits near the torsion bars? For like adjustment? It may be possible to remove one of the bars and drop or raise it by a few notches to give it extra torsion. Of couse, be careful when removing them as they tend to be a bit spingy!
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-14-2005, 09:40 PM   #7 (permalink)
Registered User
I will check this out Friday
