Originally Posted by alokbhaskar
I have a check light indicator and have codes p0171/p1133/p1135 that look like pointing to the A/F Sensor.
Could u get the A/F sensor at better price and were u able to replace it yourself or have to give it to a dealer?
I want to try to replace it myself if it is'nt a great deal. Don't know its exact location. Mne is a Toyota Camry 97.
Thanks
You can do it yourself (I've done it on my car...). Its on the exhaust though, so its probably stuck on there tight. If you want to do any work on your car get a repair manual (Haynes, Chiltons, or official Toyota) and check it out. The main a/f (or oxygen) sensor is on the exhaust just below the manifold, assuming you have a 4 cylinder. Just make sure you have the correct part if you do it yourself. So, just get a repair manual and read up on it to see if you think you can do it.
-Charlie
