SV21circuit relay problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2005, 10:38 PM   #1 (permalink)
View z3132432's Photo Gallery
I've got a aussie sv21, being the caring camry owner i am i decided to give the engine bay a bit of a clean, i loaded it up with decreaser and off i went ready to clean, however when i went to re-start the beast it wouldn't. It turns over but there was no fuel getting to the spark, which was cause by the lack of fuel pump action later noticed. I connected the diagnostics between b+ and Fp and the fuel pump worked once the open circuit relay was bipassed. SO the fuel pump is fine and all point lead to the Open circuit relay, however im sure i must have cause this fault somehow during the washing phase, and don't want it to re-occur if i put a new relay in. Has anyoe else had this fault, also my thermofans are going as soon as i turn the key to ignition, anyone have any ideas why this is????....
z3132432 is offline   Reply With Quote
Old 07-15-2005, 03:37 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Circuit opening relay is below the ecu and the ecu is behind the dash. So I don't see how it could of got wet.
Your sure that your getting spark? Remove the distributor cap and check for water inside of it. If you didn't cover up the distributor, water most likely got inside of it.
For the fans, check the fan relays. Theres 3 of them.
"Skoolin' the unlearned!"
Old 07-23-2005, 03:42 AM   #3 (permalink)
tis all good, thanks for help, it was the circuit opening relay though, i must have shorted something in the engine bay, or by som strange coincidence it went at the exact same time, either way, the old girl is goin again, cheers
