2vz knock sensor problem help plz!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2005, 01:20 AM   #1 (permalink)
Just trying to turbo
theman33b's Avatar
View theman33b's Photo Gallery
2nd Generation 2vz knock sensor problem help plz!!!!
OK I have been searching for months and have come up with nothing i have looked in manuals searched the web and still nothing. I need to know how many knock sensors a 1991 toyota camry 2vz (V6) has, and i need to know how to replace them because i keep getting the 52 error code and my car runs like shit (19.6 et quarter mile) I know the 3vz has 2 but what about the 2vz? If anyone has any advice or anything i would greatly appreciate it. thanks in advance.
theman33b is offline   Reply With Quote
Old 07-15-2005, 03:59 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I'm pretty sure it has 1 knock sensor, and it's under the intake manifold. To get to it, remove the intake plenum, coolant bypass lines, and maybe the fuel rails, and then remove the intake manifold. Should be right under there.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-15-2005, 05:08 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Yup, should be under the lower intake manifold. They screw into the cylinder head.
http://www.autozone.com/servlet/UiBr...3d8013ebdd.jsp
"Skoolin' the unlearned!"
Old 07-15-2005, 09:49 AM   #4 (permalink)
theman33b's Avatar
I can see under the intake and i dont see anything under there are you guys positive its under there because i dont want to take the entire intake off to find out its on the side of the block.
Old 07-15-2005, 05:24 PM   #5 (permalink)
VeeZed
If you have a "2VZFE" Gen 2.5 (90-91), then YES, it is under the intake manifold.
If you have a 2VZFE from a Gen 2 (88-89), then you don't have a knock sensor at all.
Old 07-17-2005, 02:35 AM   #6 (permalink)
theman33b's Avatar
ok Thanks guys time to start tearing into it.
Old 07-17-2005, 09:37 AM   #7 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
you will have to remove:
airbox
intake plenum/tb
fuel rails
intake manifold
when reinstalling fuel rails, make sure you've got all the injectors lined up well before you tighten things down. And make sure you have the injectors seated into the rails correctly, as I tore an oring doing this and had to redo it, after already replacing all of the rubber on the injectors (orings, grommets, insulators).
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
