transmission indicator light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2001, 10:37 AM   #1 (permalink)
View Mark's Photo Gallery
Whats up boys & girls.. My transmission light is dead, and rather then reading the manual and looking into the fues box (i'm lazy) I was wondering if anyone would know if it would be the light or a fues. I figured that if it was the fues, more lights would be off in the interior, but that is not the case. Hopefully I can get a reply soon so I can go to good old Canadian Tire and fix this today.. Thanks
-peace
'99 Accord EX-L 5spd Coupe
'97 Camry CE
TAC/TT-CC
Mark is offline   Reply With Quote
Old 10-22-2001, 12:40 PM   #2 (permalink)
View banana's Photo Gallery
should be the light,
too bad it ain't the fuse...
If you were planning to make other changes, now is the time... :wink:
banana is offline   Reply With Quote
Old 10-22-2001, 02:49 PM   #3 (permalink)
I went to a Toyota dealer today, and they said it costs $1 for the bulb, and $100 to replace (aprox. 1hr of service). The whole console starting from the arm rest/box must be removed in order to get at it. f*** that sh**, I'll just wait until I kill this trans. and get a standard box.
'97 Camry CE
TAC/TT-CC
Old 10-22-2001, 02:52 PM   #4 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700865
iTrader Score: 6 reviews
View EKam's Photo Gallery
Huh? If it's just the light bulb, I can change it for you for $50! :wink:
I think it only took me like 10 minutes to take apart of that and put a red bulb in there.
You got a haynes manual? Hmm actually you don't even need that, just pray the upper plastic piece open along the side opening and you will see the light bulb sitting right underneath.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 10-22-2001, 03:52 PM   #5 (permalink)
Kamuri, they told me the whole console would have to be removed. What piece are you talking about to remove? The bulb is underneath.
'97 Camry CE
TAC/TT-CC
Old 10-22-2001, 04:03 PM   #6 (permalink)
EKam's Avatar
Just want to clarify, you're talking about the transmission indicator right at the gearbox right? If that's case, it's not necessary to remove the whole console in the first place. If you're talking about the light inside where the rev/speedometer sits, then you'll need to spend about an hour to remove the console and put the light back in.
Old 10-22-2001, 10:22 PM   #7 (permalink)
Yeah, its the gear/transmission indicator, (P,R,N,D,1,2).
'97 Camry CE
TAC/TT-CC
Old 10-22-2001, 10:27 PM   #8 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
$100??? On my 92, I can change in it 45 seconds...all i have to do is remove the bezel, then a black trim piece and that's it!
The 97 must be different...or else they're screwing you big time!
Silver Streak is offline   Reply With Quote
Old 10-22-2001, 10:57 PM   #9 (permalink)
Yah, I'm pretty sure there's a difference between 92 and 97.. Whats the bezel?
'97 Camry CE
TAC/TT-CC
Old 10-23-2001, 02:06 PM   #10 (permalink)
View speedemn's Photo Gallery
You still have to take the whole front end and dash apart before you remove the bezel, no? I don't think it should take more than half hour to 45 min for the dealer but they'd like to charge an hour.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 10-23-2001, 05:42 PM   #11 (permalink)
Luc
View Luc's Photo Gallery
You don't need to remove the armrest at all. The auxiliary cigarette lighter, "trapezoidal" plate, and shifter panel are all one piece. The area around the shifter is held down by clips. So pry them up and pull back towards the rear of the car. You may want to put the gear into 'N'eutral first for more room to turn the panel. Then disconnect the lighter plug. You probably will have to release the plastic panel over the gear indicators to see the burned out bulb. Use a small flathead screwdriver for that.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Gen2 Camry Transmission Swap's milo 1st & 2nd Generation (1983–1986 & 1987-1991) 7 06-08-2003 01:05 PM
Mister Transmission in Markham Im_a_dickhead Feedback: Buyers, Sellers, and Vendors 4 07-31-2002 09:43 PM
New Transmission Consynx General Discussion 0 04-03-2002 05:18 PM
Installed Remote Start in a 1996 camry, now transmission mal critikal 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-03-2002 09:29 AM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
