I had a A/C clutch seize on me while on my way to a DB Drag race in hesperia, I was taking the I-15 going up thru the pass and as anyone in the So Cal area knows thats a bit of a climb, found out it was the clutch when I got out there, but I dident know enugh of what had happend to do anything about it... turns out the damn clutch ground the end off the compresser, so I had to replace both, I was being cheap and bought a rebuilt clutch and went to the junk yard to find me a compresser.. no luck in finding a good one kinda lose all intrest in fixing it after that, flash forward 2+ years and now its getting hot again so I get a rebuilt compresser and clutch and now the A/C butten wont turn it on... I can force it by givin it power but then I dont get the car telling the clutch to shut off when it needs to r reving the sngien higher like its supposed to. also before all this happend the A/C butten light that indacates its on started to blink, and I wouldent get any cold air out of it, I could turn it off andf turn it back on again and it would be ok for awile, but the last time it did it it never came back on.
I have looked for an A/C fuse or a braker but cant seem to find one anyone got any clues?
looked under hood and drivers side kick panel but no dice
