one headlight aimed a bit higher than the other - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2005, 05:38 AM   #1 (permalink)
View chinkywoo's Photo Gallery
i have a problem and was wondering if anyone could help me. i just installed H4 HIDs onto my 99 camry (but still, ive had this problem before i had HIDs). for some reason, my driver side light seems to be aimed a bit higer than my passenger side light. anyone know how i could lower it or fix this problem? it seems that when i dirve at night, it mite be a little to birght for ppl in front of me.
chinkywoo is offline   Reply With Quote
Old 07-19-2005, 06:06 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
On the fender side of the lamp housing there is an adjustment knob on the adjusting screw.
See: http://www.toyotanation.com/forum/t87813.html middle picture for the passenger side light, you other one is similar.
Firstly, shine the light onto the wall or garage door and mark with tape. adjust a tiny bit only, as a little adjustment means alot when you are trying to light up the road 100 meters in front of you.
If you are out of the adjustment screw's range, there is a pivot nut near the top, and you can turn that counter clockwise to aim down the headlight as well. You should remove your side marker to access that. Use a 10mm open end wrench.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
