It's a ghost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2005, 08:15 PM   #1 (permalink)
wormhole's Avatar
View wormhole's Photo Gallery
4th Generation It's a ghost
Well, I've come to the conclusion that my car has a ghost. Last year I had my struts and strut mounts replace but still had that clunking nosie. Well, today I went back to have ti looked at again. They tore though my suspension to try to find the problem but to luck everything is fine. So I've now come to the conclusion that my car has a ghost. If any one has any other idea what it might be let me know.
wormhole is offline   Reply With Quote
Old 07-19-2005, 08:27 PM   #2 (permalink)
View yosh's Photo Gallery
Is your car lowered?
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 07-19-2005, 08:36 PM   #3 (permalink)
wormhole's Avatar
4th Generation
nope.
KYB GR-2 upper front (sturt mounts are kyb)
monroe in back
Old 07-19-2005, 09:58 PM   #4 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
where did u get ur strut mounts from. i need them also...thanks
lucanhookup is offline   Reply With Quote
Old 07-19-2005, 10:11 PM   #5 (permalink)
wormhole's Avatar
i think it was like autobarn or something like that
Old 07-19-2005, 11:23 PM   #6 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
R u sure its not yoru spare tires clunking around in the back?
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 07-19-2005, 11:29 PM   #7 (permalink)
wormhole's Avatar
4th Generation
The guy that looked at said take it to see if is making the nosie but as far as I know it's securely fastened down
Old 07-20-2005, 12:22 AM   #8 (permalink)
View alxch1n16's Photo Gallery
check your rear sway bar bushings. when they wear out and dry up they will allow the rear sway bar to rattle around. at least thats whats going on on my gen3
alxch1n16 is offline   Reply With Quote
Old 07-20-2005, 12:53 AM   #9 (permalink)
View Ranger X's Photo Gallery
This is a common problem with gen4 camrys...mine does it too. The design of the strut mount is very poor, apparently. Did they examine every piece of the suspension thoroughly?
Ranger X is offline   Reply With Quote
Old 07-20-2005, 01:19 AM   #10 (permalink)
View fox_prime's Photo Gallery
i have the exact same clunking noise. you're probably missing a plate (w/the bearing) that goes under the strut mounting plates. as far as i know on my 2000 camry, there are a total of 3 plates that go under the strut bar (if you have any).
i haven't got my plates installed due to problems (couldn't put them in due to spring compression issues). but when i get the plates in this weekend i'll let you know if the clunking noise is gone or not.
fox_prime is offline   Reply With Quote
Old 07-20-2005, 01:05 PM   #11 (permalink)
Are you talking about the radial ball bearing in your strut mount? Does this clunking occur only when you turn your wheel? Just wondering what plate you're refering to.
2000 Camry LE V6
TRD Supercharged
Old 07-20-2005, 01:59 PM   #12 (permalink)
EXACTLY! The clunking noise occurs a lot when i turn the wheel. Another kind of noise occurs when i go over some bumps on the road sometimes, where it sounds like something is loose. Hopefully the bearing plate will fix both noises.
Maybe the clunking will go away after some time for the struts/springs to get used to being used a lot?
Old 07-20-2005, 02:15 PM   #13 (permalink)
View bassthrive's Photo Gallery
Ah yes clunk in the trunk revisited....
I had this problem on my solara. Big bumps would make a dull clunk originating from the rear passenger strut. Ended up being the muffler (apexi WS) bouncing up and hitting the frame. Real easy to fix - haven't heard the clunk since.
now with 100% more clickability
bassthrive is offline   Reply With Quote
Old 07-20-2005, 02:47 PM   #14 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
get the 1999 strut mounts (i went tro three sets myself). I'm on my 4th set at 78K miles.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 07-20-2005, 04:44 PM   #15 (permalink)
Alright. The clunking when you turn the wheel is caused by a bad strut bearing. Same thing happened to me and when I opened the strut mount up the bearing was busted and all the balls were falling out. Replace the bearing and it will go away. Mine was passenger's side and the driver's side was fine.
For the other clunking, if all your bolts are torqued down properly you may be out of luck.
2000 Camry LE V6
TRD Supercharged
