Acceleration Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2005, 01:20 PM   #1 (permalink)
View spear2's Photo Gallery
2nd Generation Acceleration Problem
Have a '89 Camry, 3sfe auto. Problem is, when accelerating from a standing start the car bogs down. Once the car is going there is no problem accelerating. Fuel pump has been recently changed. Sparkplugs are fine. Changed one of my 2 o2 sensors yesterday. I am thinking it could be a fuel injector leak as the gas mileage has gone down. Any suggestions?
spear2 is offline   Reply With Quote
Old 07-20-2005, 01:21 PM   #2 (permalink)
Forgot to mention that sometimes it bogs so badly that the car turns off!
Old 07-20-2005, 01:42 PM   #3 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Does the engine idle fine? Can you rev the engine without any problems in Neutral?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 07-20-2005, 02:59 PM   #4 (permalink)
Yes, the engine idles fine. I can rev in neutral, however, sometimes when you hit it hard there is a hesitation at low rpm.
Old 07-20-2005, 03:20 PM   #5 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
check the spark plug cables
Nuke209 is offline   Reply With Quote
Old 07-20-2005, 04:17 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308675
Possibly the ignition coil...
-Charlie
Old 07-20-2005, 04:31 PM   #7 (permalink)
What the Pho?
View SolaraTRD's Photo Gallery
clean out throttle body?
Could be sticky after many years
~TN.com Unofficial AIM list~ Updated: 2-23-08
SolaraTRD is offline   Reply With Quote
Old 07-20-2005, 04:47 PM   #8 (permalink)
Replaced engine & trans 30k miles ago, with engine from Japan. So engine should have approx. 70-90k by now. The engine had an external coil, unlike our US cars, so I put a Jacobs variable ignition coil along with Nology sparkplug wires (has approx. 30k now). Also have pacesetter header, complete 2" exhaust and K&N cone type airfilter.
Old 07-20-2005, 06:42 PM   #9 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
aahhhhhh, now we have the rest of the story
Old 07-20-2005, 09:50 PM   #10 (permalink)
Boondock Saint
View 89SV21's Photo Gallery
I have an 89 3sfe auto tranny equipped gen2 just like you do and have experienced similar problems in the past. what i did first was clean out the throttle body like one of the other members suggested. then i decided to adjust my throttle cable tightness by loosening the nuts on either side of the throttle cable and then pulling the cable away from the throttle body. make sure not to tighten it too much and to retighten the nuts after you have the cable in the desired position. after doing this, the acceleration was much improved and the engine didn't bog nearly as bad.
"Fur pie doesn't sell"
89SV21 is offline   Reply With Quote
Old 07-20-2005, 10:01 PM   #11 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
check the tube in between the mass air and the manifold for air leaks
Old 07-23-2005, 12:15 PM   #12 (permalink)
made it over 300K!
View 90 Gen2's Photo Gallery
with automatic transmission?
Check your throttle position sensor as well - this was the cause of similar problems with ours.
Pretty inexpensive and easy to replace.
Further "zero tools" test would be this:
floor it in transmission "power" mode.
do shifts happen before redline, maybe around 5500?
If so, throttle position sensor not giving correct signal to tranny computer.
90 Gen2 is offline   Reply With Quote
Old 07-23-2005, 07:25 PM   #13 (permalink)
View azz419's Photo Gallery
I would be investigating vacum leaks as well, I have had many cars with bad accelleration which was vacum leaks. Plug leads could be a possibility as well.If it isnt an OEM ignition system there could be issues with spark voltage and so on... I would start with running around with a can of carby clean, clean and check for vacum leaks. DOn't forget to spary the injectors as well.
azz419 is offline   Reply With Quote
Old 07-23-2005, 07:28 PM   #14 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
eeeehhhhh, carb clean, i like a spray bottle with water
Old 07-28-2005, 03:31 PM   #15 (permalink)
Looks like problem solved! Did a fuel filter change and throttlebody cleaning. Both were very dirty. Fuel filter was extremely dirty! Car doesn't bog anymore.
Thanks guys for all the help!!!!! Much appreciated.
