I'll bite
Here is the link... http://www.teamdelsol.com/howto/coldair/diycoldair.htm
What I have done is 2.5" OD steel pipe with high-temp silicone couplers to a flexible marine grade 2.5"ID pipe through the stock air intake opening, 90° pipe directly to a 3" intake opening, Cone filter hanging in front of the drivers side front wheel in the fender.
Onother option might be to move the wiring harness next to the battery and under the fuse/relay block that is in front of the stock air box location, and run the pipe forward from the tb to behind the headlight, and 90° down the conveinent hole behind the headlight, and hang the filter behind the front bumper. A little more exposed to the elements there than where I have mine though
I have pictures finally (Silver Streak was waiting for those!) but since i am at work now, I'll have to wait to tonight and post them from home.
Keep an eye open here for pics later tonight !
Cheers,
