about safc - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2005, 11:29 PM   #1 (permalink)
pkchi's Avatar
View pkchi's Photo Gallery
4th Generation about safc
hi there i was wondering if there is anyone who has safc on a 5sfe engine can share their settings becuz i don't have money for a dyno run after the safc
(the only performance mod to my car is a SRI and i was gonna put on a muffler later
pkchi is offline   Reply With Quote
Old 07-23-2005, 12:43 AM   #2 (permalink)
View 94CoupeV6's Photo Gallery
Duuuude this question has been asked, SAFC are more for forced induction cars or built NA cars. Buying one for your 5SFE will result in a very, very minimal power increase.
94CoupeV6 is offline   Reply With Quote
Old 07-23-2005, 01:05 AM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
^ I dunno man, I got myself a Powerchip ignition computer, on my mostly stock V6. Just by changing the timing throughout the rev range, increased the power noticebly. So perhaps, it's not that bigger waste, and also, you have the "option" to make changes as your mods increase.
And you didn't actually answer his question....i don't think he was after your opinion...
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-23-2005, 02:57 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
a safc cannot change timing, which is where more of your gains are coming from.
do a safc guide search there one one baclk earlier... something about tuning each rpm step until the exhasut note gets a bit burbly or something.
terrastrife is offline   Reply With Quote
Old 07-23-2005, 04:49 AM   #5 (permalink)
VeeZed
So there SAFC can only tune Air/Fuel ratios etc. This may be an interesting product in conjunction with my ignition computer. Both would then be re-programmable too, so it could be "fiddled" with. After a few engine mods, in may come in handy to have something like this!
Old 07-23-2005, 09:19 PM   #6 (permalink)
VeeZed
Mmmm eye candy.
Old 07-23-2005, 10:50 PM   #7 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
My thoughts on an S-AFC II before many mods are as follows:
I think it's a good thing to have for future upgrades. It won't get you 50hp but once you start adding other things, you'll be glad you got it. It's a matter of being prepared. I just wouldn't count it as a great power-getter at the moment.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 07-23-2005, 11:05 PM   #8 (permalink)
VeeZed
Hmm..Im really considering the SAFC/SAFCII. I think it would be great to have with my ignition computer and ill be able to adjust things on the fly when i do more mods, especially when my modded 2VZFE goes in ahaha. What would ppl recomend, SAFC I or II?
Old 07-23-2005, 11:10 PM   #9 (permalink)
Zzzz
S-AFC II definitely. The S-AFC doesn't have as much precision as the S-AFC II, I don't think it connects in to the knock sensor, nor do I think it's capable of as many adjustments or as close together.
-mark
Old 07-24-2005, 12:25 AM   #10 (permalink)
VeeZed
Even if my engine doesn't have a knock sensor? Would that be a problem>
Ufoz - You say it doens't do much if not anything on a stock engine..but with the mods i've got..do you think it would make any difference? If not just to get rid of the crappy mapping that these cars have usually?
Old 07-24-2005, 12:39 AM   #11 (permalink)
Zzzz
I'm sure your engine has a knock sensor. Contrary, to what most believe, the 5S-FE does have a knock sensor.
Further more, I don't think the knock sensor is crucial for the use of an S-AFC, although it adds to it's benefits.
-mark
Old 07-24-2005, 12:41 AM   #12 (permalink)
VeeZed
I don't have a 5SFE, i have a 2VZFE. There where 2 different models of the 2VZ. One from 88 to 89 which doesn't have a knock sensor, and one from 90+ which does have a knock sensor. I have the one which doesn't.
Old 07-24-2005, 12:53 AM   #13 (permalink)
Zzzz
I'm aware you don't have a 5S, I was making a point, since some people seem to think the 5S doesn't have a knock sensor.
-mark
Old 07-24-2005, 04:18 AM   #14 (permalink)
the powerchip is a piggyback it changes a/f too.
Old 07-24-2005, 05:00 AM   #15 (permalink)
VeeZed
Dude, if you don't know what your talking about, then don't post...
The Powerchip does in NO WAY change a/f ratio. It is an "IGNITION COMPUTER". It doesn't do anything to any fuel mapping or air or fuel ratios at all. Hence why Powerchip are bringing out a new model in the next few months with fuel and a/f ratio adjustment aswell.....
Noob....
