CD stuck in player - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2005, 04:07 PM   #1 (permalink)
View Heynow's Photo Gallery
CD stuck in player
Hi all,
I just bought a new 2005 Camry LE and when I placed a CD in the player nothing happened. I can't select the CD or eject it.
Any suggestions before I take it back to the dealer?
Thanks!
Political Forums
Heynow is offline   Reply With Quote
Old 07-23-2005, 04:26 PM   #2 (permalink)
View majorgercko1's Photo Gallery
unplug the battery maybe that will do it.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 07-23-2005, 05:17 PM   #3 (permalink)
Would popping out the fuse have the same affect?
Thanks!
Political Forums
Old 07-23-2005, 05:37 PM   #4 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
take a credit/debit card, stick it under the cd and press eject. it should work, happened on my gen4
toyotaholic is offline   Reply With Quote
Old 07-23-2005, 05:54 PM   #5 (permalink)
Thanks, but that didn't work. There is a silver bar with an orange stipe right in the middle and that's blocking me from taking the CD out.
Political Forums
Old 07-23-2005, 08:49 PM   #6 (permalink)
toyota200x's Avatar
View toyota200x's Photo Gallery
Hey my mom has the same problem with hers. I would really like to know how to get it out. Anyone else have this problem?
toyota200x is offline   Reply With Quote
Old 07-23-2005, 09:54 PM   #7 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
Originally Posted by Heynow
Hi all,
Thanks!
its still under warranty ...if all tries fail, take to dealer
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 07-24-2005, 07:40 AM   #8 (permalink)
99 Camry LE
View Gachinto's Photo Gallery
My oem deck from gen4 has problem and I BELIEVE there's a disk stuck inside too ~ I have used an aftermarket one for quite awhile while my oem one sit in box ... I am about to just take the deck apart to see what happens ~
Gachinto is offline   Reply With Quote
Old 07-24-2005, 10:19 AM   #9 (permalink)
I took it back to the dealer and they have to order me a new player (approximately two weeks).
The problem was the disc size - "The player is intended for use with 12 cm (4.7 in.) disc only."
I used one a little too thin, even though it works on all other disc players, just not this one.
Edit: Actually I was using 12 cm - Memorex. Maybe it was a compatibility issue.
Thanks all for the suggestions.
Political Forums
Old 07-24-2005, 11:34 AM   #10 (permalink)
Needs To Speed
RiZLA's Avatar
View RiZLA's Photo Gallery
thats pretty retarded, a cd player should be able to handle all sizes.
RiZLA is offline   Reply With Quote
Old 07-24-2005, 12:20 PM   #11 (permalink)
Gameroom cash: $304455
I know a Mazda tech and he told me recently that Mazda recommends against using burned CDR's in their new decks. He said if it happens, Mazda will pop for a new deck one time if it jams. After that, the customer is on their own and these things are pretty expensive. Read your manual and see if Toyota says anything about CDR's.
Mike
Old 07-24-2005, 01:35 PM   #12 (permalink)
All it states is that Copy Protected, CD-R, CD-RW and CD ROM may not be playable.
My 2000 F-150 plays all fine...are they going backwards in technology?
I wonder if it has something to do with the quality of the CD-R. I was using Memorex and I know Verbatim is one of the best brands, but now what if I try that and it does the same? I should be covered since it does not state "DO NOT USE CD-R".
I hope I don't have to dump all my CR-R's.
Political Forums
Old 07-24-2005, 06:40 PM   #13 (permalink)
toyota200x's Avatar
If I took my car to best buy or a stereo shop would they know how to get it out?
Old 07-24-2005, 08:07 PM   #14 (permalink)
Ninja-rator
don't know....is it the oem deck or something they installed...what is your car? stock deck?
try asking first if they know know.....labor is expensive
