fuse for lower dc power? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2005, 06:29 PM   #1 (permalink)
MykeLefty's Avatar
View MykeLefty's Photo Gallery
does the power socket underneath the cig lighter in the 97 camry has its own power fuse?
if so where?
i cant get mine to work
'97, Gen 4 Camry LE
The Black Stripes
MykeLefty is offline   Reply With Quote
Old 07-24-2005, 03:17 PM   #2 (permalink)
MykeLefty's Avatar
? please help
'97, Gen 4 Camry LE
The Black Stripes
Old 07-24-2005, 09:15 PM   #3 (permalink)
View lenjack's Photo Gallery
I don't recall, but you can check out the labeled fuse panel behind the little coin compartment.
lenjack is offline   Reply With Quote
Old 07-25-2005, 02:01 AM   #4 (permalink)
MykeLefty's Avatar
what fuse panel behind the coin compartment?
the only fuse panel i know of is the one under the hood.
'97, Gen 4 Camry LE
The Black Stripes
Old 07-25-2005, 03:54 AM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308675
Try looking behind the coin compartment to the left of the steering wheel.
Also, make sure the key is in the accessory or on position when you test for power.
-Charlie
Old 07-25-2005, 06:33 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
On the socket itself, the (+) contact, there is a fusible link that will burn out. On mine it is covered by a pinkish piece of rubber insulation. Pull it out and check the back of it. If it is burnt, you can put a piece of solder there and re test. If it works after, then go to a junk yard and pick one up.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 07-25-2005, 01:26 PM   #7 (permalink)
MykeLefty's Avatar
yeah its definitley busted, so i guess ill try and find a fuse, thoguht im pretty confsed about how to do that.
'97, Gen 4 Camry LE
The Black Stripes
Old 01-30-2006, 05:57 PM   #8 (permalink)
View leddy's Photo Gallery
I've got the same problem. I don't suppose the power socket will come out the front some how. Did you have to tear apart the console panels to access the back?
leddy is offline   Reply With Quote
Old 01-30-2006, 06:31 PM   #9 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
^ the power socket is attached to the shifter trim which pops out by pulling straight up.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 01-30-2006, 07:33 PM   #10 (permalink)
Moving Forward
View Cyorke's Photo Gallery
If you are having trouble finding the fuse it is behind hte coin holder to the left of the steering wheel. Open the holder and then you can look behind it and see the fuse block. jsut pull pretty firmly and the coin holder should come out. theh you can access the fuses. I know my Sienna has a separate fuse for the DC socket and the compass/auto dimming mirro among other things. You are best off looking in your owners manual because with a Toyota it may not say plain as day on the fuse diagram which one is for the socket. If you look in the manual it lists out what components are controlled by each fuse.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 01-30-2006, 08:00 PM   #11 (permalink)
Darkside Cut Me!!!
In the gen 3's and 4's the extra power socket uses an intergrated fusible link.
2004 RX330 Sport
2003 Cam I4 XLE
