Please help me with my Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2005, 03:49 PM   #1 (permalink)
View smoothy_bj's Photo Gallery
Went to start my 1991 Camry last night, and no go. The engine cranks but will not start the car. The battery is NOT dead. All electrical systems in the car are working except the headlights and the radio. (Turn signals, brake lights, and fans all are working.) Tried to jump it just in case the battery was weak, but no go. I checked all of the fuses in the engine compartment and both kick panels, and everything is ok. Any ideas?! Please help me!!!
smoothy_bj is offline   Reply With Quote
Old 07-24-2005, 04:07 PM   #2 (permalink)
cam2Xrunner's Avatar
Might be a long shot, but in the fuse panel that is in the engine bay above the left fender take out the EFI fuse and replace it with the AC fuse. Then try to start it. Same thing happened to my mom's 91 camry a while back. The EFI relay was loose.
Old 07-24-2005, 05:55 PM   #3 (permalink)
no luck w/ switching the fuse.
Old 07-24-2005, 08:14 PM   #4 (permalink)
View karazy's Photo Gallery
Pull a plug to see if you have spark. Next stop is fuel pump.
karazy is offline   Reply With Quote
Old 07-24-2005, 08:16 PM   #5 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
did you have recent work done on it?
Is there an engine light?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 07-24-2005, 10:07 PM   #6 (permalink)
限界域への独走。
View mobes's Photo Gallery
His headlights and radio don't work either, thus the fuse speculation. Given that, I doubt it's the ignition or fuel pump.
Brian: good luck, we'll get to the bottom of this on Tuesday if you don't have it running by then.
mobes is offline   Reply With Quote
Old 07-24-2005, 10:20 PM   #7 (permalink)
Neither of those systems affect the car starting. He seems to think the fuses are ok. Confirming these items are there, or not, help to narrow down the problem.
Old 07-30-2005, 03:35 PM   #8 (permalink)
限界域への独走。
Turns out the problem was one of the main power wires was pulled out of the bottom of one of the fusible link connectors on the (+) terminal of the battery. Re-seated it and it started right up.
