question on my camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2005, 04:35 PM   #1 (permalink)
New Camry Owner
View bballandtennis7's Photo Gallery
i just bought a 96' toyota camry, and it needed work done on it along with a new battery. they put a battery in there, but there is no bracket holding the battery in. i'm wondering if this will be a problem, or should i just forget about it?
Say hello to my little friend!
http://www.cardomain.com/ride/2040689
bballandtennis7 is offline   Reply With Quote
Old 07-24-2005, 05:04 PM   #2 (permalink)
View karazy's Photo Gallery
You definitely should have it clamped down. The brackets are cheap and easy to find. Make sure they didn't convert it to a bottom clamp style.
karazy is offline   Reply With Quote
Old 07-25-2005, 12:13 PM   #3 (permalink)
Gameroom cash: $304455
karazy is right. If the battery keeps bouncing around, it's life will be greatly reduced. This bouncing will eventually break up the plates inside. I would try to find one on a car at a boneyard. It should be relatively cheap. If you can't find one at a boneyard, there is always the dealer. Until you get one, I would recommend a rubber tiedown strap as a temporary measure; remember, this is only a temporary measure to minimize the bouncing of the battery.
Mike
Old 07-25-2005, 12:30 PM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
find "J" brackets at a autostore/place that sells batterys and those should be suffice to tie down your batter to the batteryplate. They are like 4 bucks for a pair!
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
