The bulbs can't be replaced with a colored #74 or whathaveyou. Painting them is my choice. Read on...
I pried the button faces off the cartridges with a small screwdriver. For the bulbs in the button, flip the cartridge over and turn what looks like a plastic screw (actually the bulb socket) with a tiny philips head screwdriver. You may need to use the tiny flathead to pop it all the way out, but once you get it its just a matter of removing the connie and painting the desired color. Sharpie works but it does not last. I suggest nailpolish. "A/C" text is a bulb. "A/C on" indicator is a LED, therefore impossible to paint. Rear defrost is the easiest - both the label and indicator are removable lightbulbs. Recirc button is the hardest since it is all LED.
- Paul
now with 100% more clickability
