Loss Power.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2005, 12:20 AM   #1 (permalink)
vL
92Camry5sp's Avatar
Gameroom cash: $221105
iTrader Score: 6 reviews
View 92Camry5sp's Photo Gallery
Loss Power..
Alrite you guys..seems like my camry is losing power..my dad told me i need a new header pipe..cause it gives me a weird noise like im losing air somewhere underneath the car..i wanna know if theres anything else that can make me lose power..my 1st gear isnt picking up like usual..and my 2nd gear tends to lag on the clutch..let me know what you guys think is wrong..
92Camry5sp is offline   Reply With Quote
Old 07-26-2005, 01:02 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
sounds about right... probably got a exhasut leak... flex pipe almost certainly, get it checked out.
terrastrife is offline   Reply With Quote
Old 07-26-2005, 10:02 AM   #3 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
check it out, flex pipe am thinking, watch out.....can be expensive
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 07-26-2005, 12:30 PM   #4 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
I had to get my flex replaced (85$ CAD because i was in too much of a hurry to weld a new one on myself)
However, couldnt it also be a plugged Cat? (or would that throw a fault code on the ecu?)
Keep is offline   Reply With Quote
Old 07-26-2005, 08:27 PM   #5 (permalink)
vL
92Camry5sp's Avatar
How much does this usually cost??And can one from the junkyard replace it?? ..YOu know..im just trying to save some money..
Old 07-27-2005, 02:42 AM   #6 (permalink)
unless you can tig(?) weld, get it done at a shop.
