ouch! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2005, 06:31 AM   #1 (permalink)
Gen V
Beeman_M600's Avatar
View Beeman_M600's Photo Gallery
Gen5 ouch!
Has anyone been experiancing excess stactic from their car body after turning off engine?
My 2003 SE 4cyl. has been giving me the shock treatment everytime I turn the car off!!!
Would a grounding belt help?
Thanks in advance....
Beeman_M600 is offline   Reply With Quote
Old 07-26-2005, 06:50 AM   #2 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
as far as i know most new cars shouldnt generate static electricity to shock you ...
most probably, the static you are feeling is generated from yourself...
your clothes, your seat, and you, are all moving around inside the car, this causes fiction and you get static electricity, since you cant discharge this static from your body whilst inside the car, when you step outside and touch the metal surface of your car, then you discharge it that way, thus feeling the shock
~ Terry
terrynham is offline   Reply With Quote
Old 07-26-2005, 06:51 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
what seat/covers do you have?
terrastrife is offline   Reply With Quote
Old 07-26-2005, 11:42 AM   #4 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
That's why you should go for the leather. Unshockable.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 07-26-2005, 01:52 PM   #5 (permalink)
MAKE ME A TACO!
BigIke's Avatar
View BigIke's Photo Gallery
Gen5
when getting out of the car just touch the metal part if the door before you leave your seat
problem solved
BigIke is offline   Reply With Quote
Old 07-26-2005, 02:11 PM   #6 (permalink)
View majorgercko1's Photo Gallery
mine was doing it all the time. I have a gen 5 too, but then it stopped. I was afrait and would like touch it as fast as posible to see if it would shock me. Oh good thing it stopped.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 07-26-2005, 05:05 PM   #7 (permalink)
Gen V
Unhappy
Yes I did put in new seat cover , and that it is just a pain in the a$$ I mean (hand) touching the metal part of the door closing it.........hence the shock .
Old 07-26-2005, 08:06 PM   #8 (permalink)
MAKE ME A TACO!
BigIke's Avatar
Like I said before you get out of the seat touch something metal, should fix it.
My 97 camry used to shock the shit outta me too
Old 07-26-2005, 09:13 PM   #9 (permalink)
hollywood dropout
View couture's Photo Gallery
I don't think leather helps, my mom had leather in both her camry's and it still shocked the hell out of me when I got out. It doesn't anymore though.
couture is offline   Reply With Quote
Old 07-26-2005, 10:53 PM   #10 (permalink)
View brazilgoal's Photo Gallery
I sometimes get a static charge when I get out of the Camry in the cold weather. I find myself closing the door with my jacket covered arm rather than with my bare fingers. My SE seat covers genrate lots of static.
Camry SE '03 2.4L Gen. 5 - Black
Manual Transmission
K&N air filter
Grounding system - Homemade
Enkei Wheels 16 in. 5-spoke alum
brazilgoal is offline   Reply With Quote
Old 07-27-2005, 02:41 AM   #11 (permalink)
guys.. stop wearing fiber based clothes
synthetic all the way!!! like engine oil!
lol.
Old 07-27-2005, 06:06 AM   #12 (permalink)
1999 Gen4 V6
AustSV21's Avatar
View AustSV21's Photo Gallery
most likely its your floor mats, just like when u rub you feet on carpet and then touch metal u get a shock. also check ur grounding wire on the battery.
AustSV21 is offline   Reply With Quote
Old 07-27-2005, 09:54 PM   #13 (permalink)
GEN 3 Driver
View mchodan's Photo Gallery
Have you recently replaced your tires? I read somewhere inexpensive tires can cause static to build up.
mchodan is offline   Reply With Quote
Old 07-28-2005, 04:51 PM   #14 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
You might think about getting an anti-static spray. I used to have to spray my 99 once a week. I found the spray in the laundry detergent isle , in your local grocery store. After a couple of weeks of doing this I stopped having to spray and now I only get shocks in the winter/ on a very dry day, which here in Texas doesn't happen very often. Hope this helps.
camry-4-ever is offline   Reply With Quote
