If you are going to take out the Middle vents, First you have to remove the radio, and with a stubby philips screwdriver, you have to reach behind the vent and remove a screw, Then for all the rest of the vents you will need a flathead screwdriver and a little bit from the top corners of the vent you have to slip the screwdriver and push down of tabs ( there are four per vent) If you push the vent's down and look into the shaft you can see the tabs. These is tricky but once you remove one, you'll get the hand of it! Good Luck
