alarm goin crazy - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2005, 07:15 PM   #1 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
Angry alarm goin crazy
hey guys,
i disconnected the battery today, and when i re-connected it, i heard the doors lock. now everytime i open the door the alarm goes off and cant start the car. i only have the spare key, my car is gen4. whats the solution?
toyotaholic is offline   Reply With Quote
Old 07-26-2005, 07:23 PM   #2 (permalink)
FloridaPino
eviltwin67's Avatar
View eviltwin67's Photo Gallery
Is it a facory alarm? I have an aftermarket alarm and if my remote doesn't work, I can put the key in the ignition turn the key until it almost cranks the engine and back to the "insert" position twice really fast and it disables the alarm. Good luck
96 V6
Amsoil foam filter
Upgraded headlight Harness w/ Sylvania Cool Blue
APS 996A Remote Start Alarm
eviltwin67 is offline   Reply With Quote
Old 07-26-2005, 07:37 PM   #3 (permalink)
its aftermarket, but i cant start the car < biggest concern
Old 07-26-2005, 07:45 PM   #4 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
My alarms been going crazy lately too. My one remote was screwed up last year so I went back where I had it installed and they reprogrammed it.
Only they programmed it that the lock button locks and unlocks the doors.
Now with the other remote, it doesn't always work. Sometimes I have to click the button like 15 times for it to register and unlock/lock the door. And the batteries fine because the light on the remote always comes on when you click a button and isn't dim.
And lately there are times i'll just click the unlock button and the doors will unlock but the siren will sound, and the only way to shut it off is to disconnect the battery.
I hate going to the shop where I got it installed so I refuse to.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 07-26-2005, 07:49 PM   #5 (permalink)
^ so how did you start the car? btw, i dont have the remotes
Old 07-26-2005, 08:00 PM   #6 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
on my camry, i got an aftermarket alarm. basically, once the alarm is on or engaged in it's yelling tantrum, the engine will not start for protection reasons.
HOWEVER there is an over-ride for that. put the key in, turn to on, then off, then on, then off and keep doing that for a little. after a certain number of times, the alarm will disengage and you can freely start the car. that's how it is in mine and what it said in the owners manual.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 07-26-2005, 08:18 PM   #7 (permalink)
Durrby's Avatar
same way as always...when it goes crazy i just pull the battery cable and put it back like normal.
Old 07-26-2005, 09:40 PM   #8 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
we really can't help you with an aftermarket alarm.....brand? model #?
they're all programmed differently and have different functions....does it have a shock sensor? perimeter sensor? auto starter? engine-disabler?
need more info, and then maybe somebody may have the same alarm as you an the installation/technical manual w/ wiring info and programming info
HaHa
Old 07-26-2005, 10:16 PM   #9 (permalink)
View Crash2Camry's Photo Gallery
The alarm I have went crazy because of the battery once. The battery died, and so the alarm would take that as the battery being disconnected, and the alarm reads that as a break in (because disconnecting the battery turns the alarm off, the second it reconnects it treats everything as a break in). I had to replace the battery and have them reprogram the alarm
Crash2Camry is offline   Reply With Quote
Old 07-26-2005, 10:19 PM   #10 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
errr....have you tried looking for the "valet" switch? when you go to start the car, put the key in ON position and depress that button untill you hear a response from your car. Then try to start it.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 07-26-2005, 10:25 PM   #11 (permalink)
00SolaraV6's Avatar
View 00SolaraV6's Photo Gallery
It's not the AudioVox SecuriKey+ system is it?
Toyota For Life
00SolaraV6 is offline   Reply With Quote
Old 07-27-2005, 02:00 AM   #12 (permalink)
no idea. it came with my car when i bought it.
yea, that did the trick. looked above the pedals and there was this red button. pressed it, started the car and vroom!! 'preciate everyones input
Old 07-27-2005, 02:58 AM   #13 (permalink)
View Ranger X's Photo Gallery
That sounds like you have the SecuriKey+...could be wrong, but my car is exactly the same way. If so...I pity you, those things are total pieces of junk. Curiously, where did you buy your car? Normally I would just press the unlock key. Next time you have to disconnect the battery, take out the relay for the horn (located in the fuse box on the driver's side under the hood). There's a diagram on the underside of the cover to tell you which one it is.
Ranger X is offline   Reply With Quote
Old 07-27-2005, 04:02 AM   #14 (permalink)
got my car at longo toyota, used car. again, i dont have the remotes. what good does taking the relay out? besides not going deaf
Old 07-27-2005, 04:05 AM   #15 (permalink)
Ninja-rator
what did longo tell you when you bought it?
