Turn Signal blinking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2005, 10:18 PM   #1 (permalink)
View Crash2Camry's Photo Gallery
4th Generation Turn Signal blinking
Ok, so I know that when you have a turn signal out that it will flash faster than normal...
My problem is, is during the day the turn signals flash fine, but at night, when the headlights are on and I use the blinker, the go fast (this is while all of them work). Obviously there is something wrong with having the headlights and turn signals on, but Im not sure what to do to fix it.
Crash2Camry is offline   Reply With Quote
Old 07-26-2005, 11:45 PM   #2 (permalink)
View CerialPhreak's Photo Gallery
Ok i think this is just an issue with translation, but if you have a turn signal out it wont blink at all, what usualy happens in my experience is that when your signal is going nuts you have a tail or brake light out, so i would turn the lights on, and take a look at the back and have a friend look to see if all your brake lights come on aswell, if that doesnt work try swapping the bulb i suppose.
CerialPhreak is offline   Reply With Quote
Old 07-26-2005, 11:47 PM   #3 (permalink)
and upon further inspection your from so cal, so maybe you meant to say what you did, sorry
Old 07-27-2005, 12:55 AM   #4 (permalink)
Gen 4 Snow Lover
View randomman84's Photo Gallery
check the connection of the prongs to the bulb i had this problem too. I just fixed it again tonight incidentily.
randomman84 is offline   Reply With Quote
Old 07-27-2005, 01:10 AM   #5 (permalink)
Carzz R Xpensive!!111
felkajamine's Avatar
iTrader Score: 11 reviews
View felkajamine's Photo Gallery
yeah this happened with mine, they would blink rapidly when the lights were on, so then put my car in park and lodged a long stick to the brake pedal and sure enough one of my brake lights were out, problem solved.
'95 5spd Scepter Coupe
felkajamine is offline   Reply With Quote
Old 07-27-2005, 04:14 PM   #6 (permalink)
Thanks for the help!
