Car Won't Start after Injen intake install? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 01:04 AM   #1 (permalink)
I eat rice for dinner.
View 1MZ-FE 5 Spd's Photo Gallery
4th Generation Car Won't Start after Injen intake install?
Ahh, bad day.. ok guys, today I installed an Injen intake for the V6, and when i started everything was fine, but when i turned off the engine and got ready for work, the engine wouldn't even start, just cranked a lil. I jumpstarted the battery and the car started and ran just fine, but when I tested if it would start after I turned off the ignition, it didnt start.. I attempted to disconnect the battery before installation, but the alarm kept going off, so I just installed it with the battery connected, Any ideas?
1MZ-FE 5 Spd is offline   Reply With Quote
Old 07-27-2005, 01:06 AM   #2 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Did you make sure you sealed it all the way? Any cracks or hole in the intake hose will mess up the engine, or in your case, not start correctly. Check it out with your mechanic.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 07-27-2005, 01:12 AM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
check your maf sensor connections....
tho I don't see how jumpstartting would work....
HaHa
Old 07-27-2005, 01:36 AM   #4 (permalink)
View 94CoupeV6's Photo Gallery
When I installed my AEM intake on my car, it would idle like crazy and then the engine would die...Took the intake piping off...and it was because I left the stupid AEM decal in the cone filter!!! LOL...
94CoupeV6 is offline   Reply With Quote
Old 07-27-2005, 01:41 AM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
maybe your battery is dead? take it and get it tested.
^ and leaving it that way!
Old 07-27-2005, 01:50 AM   #6 (permalink)
Alrighty, thanks for the advice, i'm taking it to Toyota first thing in the morning, anyone smell a vacuum leak problem?
Old 07-27-2005, 02:35 AM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
not vacuum leak, even with a leak you would still run.
terrastrife is offline   Reply With Quote
Old 07-27-2005, 02:51 AM   #8 (permalink)
View Ranger X's Photo Gallery
That's pretty weird...does sound like an MAF problem though. When I put my intake on I had the MAF in backwards at first (didn't mark the pipe ends ), and it did what you described...just cranked a little then died.
Ranger X is offline   Reply With Quote
Old 07-27-2005, 03:51 AM   #9 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
eh.... when you installed the intake, did you connect the air sensor thingy? if you didnt, just that little sensor can keep your engine from not working properly, or in your case, not start.
MadDawg is offline   Reply With Quote
Old 07-27-2005, 03:55 AM   #10 (permalink)
View yosh's Photo Gallery
Sounds like a battery problem if you were able to jump start it.
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 07-27-2005, 04:54 AM   #11 (permalink)
check your batter-chassis ground cable, its probably gone if you were able to jump start (clamping positive and radiator) you probably tore it off mucking around in the engine bay.
Old 07-27-2005, 08:09 AM   #12 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
did you connect all of the accum lines? that was where mine got screwy
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 07-27-2005, 09:46 AM   #13 (permalink)
hey, any idea where the battery chassis ground is?
Old 07-27-2005, 09:47 AM   #14 (permalink)
View mcelligott's Photo Gallery
Crankcase breather attached?
Turbo 3vz-fe with Nitrous...you have questions? I have answers, Get a hold of me on aim!
mcelligott is offline   Reply With Quote
Old 07-27-2005, 10:48 AM   #15 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
it shouldnt really have anything to do with the intake
I've started the car without an intake pipe before (to see if any leaks)
and it worked
Probably battery or something needs to be plugged back in?
Try to retrace your steps
Nuke209 is offline   Reply With Quote
