OMG, i think my engine mount were installed...wrong - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 01:51 AM   #1 (permalink)
View novalogic88's Photo Gallery
Question OMG, i think my engine mount were installed...wrong
1995 lexus es300
well, i recently bought a dogbone, and an engine mount which is below the radiator, that looks like a triangle, i bought them both coz i thought they should stop the engine from moving when changing gears/accelerating
after the install it still did the exact same thing, the bloody engine still moved, and yes its very noticeble, i chcked under the hood the parts are the ones i bought, but the mount which is under the oil filter MIGHT be installed incorrectly
when u look from top of the hood, is it suppose to look flat or.... coz im pretty sure the engine isnt suppose to move like that under acceleration, changing from P to R/D etc.
novalogic88 is offline   Reply With Quote
Old 07-27-2005, 01:58 AM   #2 (permalink)
cam2Xrunner's Avatar
There's supposed to still be slight movement, but you might have other mounts gone bad.
Does it jump more when you put it in reverse or drive?
Old 07-27-2005, 02:18 AM   #3 (permalink)
when its in neutral or park, and i press the accelerator it says dead still.
when i put it in d or r, it starts to either rock foward or backward
i just tested it out, it goes up and foward when i press the accelerator whilst its in D
i did this wif the hood open, one foot on the brake one on the accelerator, and my friend watching the engine move, and i could also see it through the gap of the hood.
Old 07-27-2005, 02:33 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
thats normal.
i have maybe... 5cm of up/down movement.
if it DIDNT move, you would be sitting on a vibrator.
terrastrife is offline   Reply With Quote
Old 07-27-2005, 08:43 AM   #5 (permalink)
Australia
holden apollo ey
fair dinkum
Old 07-27-2005, 11:32 AM   #6 (permalink)
that guy
View xylium's Photo Gallery
If it's moving a couple of inches, then I'd check the back mounts. If it moves more when you apply the brake and put it in reverse, it's the back engine or tranny mount, I beleive there is two back there.
Totally stock 00' 4cyl in Sage. Looking for set of nice stock 15" alloys for cheap, got any?
xylium is offline   Reply With Quote
