My steering wheel vibrates at 120kmh - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2002, 07:07 PM   #1 (permalink)
View Ken4's Photo Gallery
I've balanced my wheels, but it still vibrates above 120kmh. What's wrong? My camry now has 52,000km on the odo. I remember at 26,000km the driveshafts, tie-rod ends, lower ball joints, & engine mounts were changed. Is it time to do it again?
Ken4 is offline   Reply With Quote
Old 09-20-2002, 07:34 PM   #2 (permalink)
View Stylus_gen3cam's Photo Gallery
do you have rims
so do have rims and if you do what size are they?????????
Stylus_gen3cam is offline   Reply With Quote
Old 09-20-2002, 08:22 PM   #3 (permalink)
Jay
View Jay's Photo Gallery
Hmm...
Did you check if the rims were bent? Mine shakes because my rims are bent... Tires definitely could be the reason.
Jay is offline   Reply With Quote
Old 09-20-2002, 09:33 PM   #4 (permalink)
View PLRBEAR's Photo Gallery
How bad is the vibration? Anything that can be related to lower profile tyres, hence a more sensitive steering wheel?
Vibrations are usually caused by bad balancing, although there sometimes can be other causes.
I remember you switched from 15s to 17s right? Where did you send the car for balancing anyway?
'99 Camry 5S-FE
PLRBEAR is offline   Reply With Quote
Old 09-20-2002, 09:57 PM   #5 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
Originally Posted by Jay
Hmm...
Please tell me it's not your new ones.
1991 Toyota Camry DX: Mods listed on Cardomain
http://www.cardomain.com/id/whitecamrydx
91camryDX is offline   Reply With Quote
Old 09-21-2002, 12:21 AM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
I'm with plrbear on this one....either balancing, or just as likely, alignments...
HaHa
Old 09-21-2002, 02:00 AM   #7 (permalink)
I balanced all four wheels twice, at two different shops, but no difference. Balance is perfect "zero, zero". Alignment feels perfect, doesnt pull left or right, and no abnormal tire wear.
I admit I am a bit rough with the car, hitting 6000rpm several times almost every day. But I am quite disappointed that the front-end components cant last long for a mere 136hp 4cyl engine.
Wonder how long those with V6s last? Or maybe those V6s have stronger front end components?
Old 09-21-2002, 02:16 AM   #8 (permalink)
Re: do you have rims
I switched from stock steel rims 15x6 205/65/15
to
aegis enkei 17 x 7 (43mm offset) w/ 215/50/17 tires
The new rims use a centering ring.
Why? Do you think my new rims are the culprit??
Old 09-21-2002, 09:49 AM   #9 (permalink)
AHHAH! Ok. Let me relate my personal experience to you. I once bought a set of wheels & tyres from a local store, and when they were mounted on my VW, the steering wheel would vibrate. I was told they were normal. However, the same wheels mounted on a Honda Civic produced no vibration at all. I later found out that the VW was hub centric while the Honda Civic wasn't (or something along those lines). Check the size of the centering ring. Do your wheels have those small centre caps? I'm wondering if the ring is the correct fit. Try fitting them on the hub without the wheel and see if they're snug. I believe that's the cause of your problem.
'99 Camry 5S-FE
Old 09-21-2002, 11:27 AM   #10 (permalink)
Jay
hah..
quote:
Originally posted by Jay
Hmm...
No..no... 19" tantrums haven't even arrived yet.. It's coming either today or Monday..
