Wrong Tire Size! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 03:53 PM   #1 (permalink)
New Camry Owner
View bballandtennis7's Photo Gallery
Wrong Tire Size!
I just bought a 96' Toyota Camry LE. I looked in the manual and it says that the tires should be like P19570R14 or something like that, but I go out and look at my tires and they are P19575R14. I went to Kaufmann and had the tires switched around because I hated the white-walls and I asked the guy there, he said that this meant my tires were a little too tall and that the speedometer would be a little off, is this bad? How much do you think the speedometer is off? Thanks for your help...
Say hello to my little friend!
http://www.cardomain.com/ride/2040689
bballandtennis7 is offline   Reply With Quote
Old 07-27-2005, 03:55 PM   #2 (permalink)
View eddiel6l's Photo Gallery
dont bug out its not that big of a deal
eddiel6l is offline   Reply With Quote
Old 07-27-2005, 04:38 PM   #3 (permalink)
Gameroom cash: $927300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
You can figure it out using this. http://www.miata.net/garage/tirecalcold.html
It will not hurt the car any.
5 Lug Corolla WHAT?
Old 07-27-2005, 04:40 PM   #4 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
dont worry about it, its fine
lucanhookup is offline   Reply With Quote
Old 07-27-2005, 04:41 PM   #5 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
On tires, the first number is the width of the tire (how much of it is actually in contact with the ground). The second number is the percentage of the first number that makes up the sidewall of the tire. The last number is the rim size.
The overall diameter of your wheels are 3.02% too big. Your speedometer is 3.115% too slow. When you're actually going 60mph, your speedometer will say that you are going 58.1 mph.
Its not really that big of a problem, but you need to be careful because if you're going too fast, and your speedometer tells you that you're going slower than you actually are, then you can get pulled over for speeding much easier. Other than that, you'll be alright.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 07-27-2005, 04:55 PM   #6 (permalink)
New Camry Owner
i think it's the other way around, because when my speeometer says i'm going 45, it seems like i'm going closer to 40. and another question, wont the total milage on the car be messed up if the tires take longer to turn around?
Old 07-27-2005, 05:23 PM   #7 (permalink)
HID/Retrofit Expert
Yes, the milage will be off as well. But as far as being the other way around, see for yourself. www.1010tires.com has a tire calculator. I wasn't making up those stats...
Old 07-27-2005, 05:49 PM   #8 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
just drive accordingly and adjust to the speed..
skewe is offline   Reply With Quote
