Replace the headlights high/low beams switch. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 05:29 PM   #1 (permalink)
View jliu66's Photo Gallery
Hi, DO you know how can I open the cover and replace the headlights high/low beams switch for 99 Toyota?
Many thanks in advance.
jliu66 is offline   Reply With Quote
Old 07-27-2005, 06:05 PM   #2 (permalink)
grrroarr... ?
View jaguar's Photo Gallery
what cover, you're a bit vague...
ps. stick to the regular font (easier reading)
94' 2.2 Camry
-fast enough to get tickets-
jaguar is offline   Reply With Quote
Old 07-27-2005, 11:02 PM   #3 (permalink)
Hi, Jaguar,
Well, suppose I need to open the cover to get and check the high/low beam headlight switch. RIght?
I found no problem with bulbs, fuse, and wiring. So there is just switch left for the problem that I have no high/low beam headlights. No matter what I turn the nob, there is no change in headlights.
Do you know where I can download the repair manual for 99 Camry LE?
Old 07-28-2005, 04:14 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ You need to remove the cover for the steering column.
The cover is 2 pieces, with screws in the lower piece.
Remove the screws, then seperate the 2 pieces.
"Skoolin' the unlearned!"
