Problem with the Auto Choke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 10:23 PM   #1 (permalink)
Ferrat
Ferrat's Avatar
View Ferrat's Photo Gallery
2nd Generation Problem with the Auto Choke
Ok i've done a search fo this, and cannot find a thing so i thought i'd ask.
Currently i have a 89 cs camry, and i'm haveing a problem with the carburetor. The accelerator kept getting stuck full open, after finding the cable freyed i replaced it. lol typical it wasn't it, just needed some lube . But either way i had to replace the cable.
But on to my problem, it kinda idles a little lower than usual, i know i need to adjust the idle knob, but it won't auto choke, i start the car and instead of sitting at 2500 rpm for 5 or so minutes to warm it up, it stays at 1000, its normal rpm. Anyone with experience in carby engines i could use some help, it gets cold down here in melbourne, and its hard to start in the morning.
Thanks all.
1989 Camry SV22 (RIP) Blown Motor
1988 Camry SV21
2001 Camry MCV20 V6 Touring
Ferrat is offline   Reply With Quote
Old 07-28-2005, 11:00 AM   #2 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
I have worked on a few carbs (carter, rochester, holley, edelbrock) but the only one that i've done a complete overhaul on was a Rochester 4bbl Spreadbore Q-Jet
It was an electric choke, but the concept is the same weather it's electric or manual.
When cold, the carbs choke door should be closed, thus giving you a fairly rich condition.
When your typical choke (a coiled bi-metal strip) heats up as the engine warms up, it turns a drop cam which pulls on linkage, turning the choke valve to the open position.
I wish I could take some pictures.
If you haven't bought a hanes carb manual or hanes manual for your car yet, i would suggest that.
The manual should have pictorial procedures on adjusting and checking all the components of your choke/idle system.
Keep is offline   Reply With Quote
Old 07-30-2005, 12:57 AM   #3 (permalink)
Ferrat
Ferrat's Avatar
i have the hanes manual for the car, but makes no reference to the choke, maybe coz there arn't many out there i dunno, its has a reference to the auto choke, and no info on it.
I think i can survive without it, and after a while i'll overhaul the carb
1988 Camry SV21
