has anyone tried this method to shorten shifter throws? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2002, 11:03 PM   #1 (permalink)
View jr_certs's Photo Gallery
http://4crawler.cruiserpages.com/Diesel/ForSale/ShiftLinkage.shtml
I know it's a VW site but it looks like the basics would work on any manual transmission. I think Patrick shortened his shifts, is this how he did it? If anyone else has done it do you have a right up on it? If not I think I'm gonna try making at least the short throw shifter arm, cause it doesn't look like anything more that $20 bucks of parts. But where can I get some new bushings for my 3sfe tranny?
jr_certs is offline   Reply With Quote
Old 09-22-2002, 01:25 AM   #2 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Re: has anyone tried this method to shorten shifter throws?
I think it wouldnt work because the shift mechinism on the camrys are hydralic while the bugs is mechinical... But, I could be wrong...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 09-22-2002, 06:29 AM   #3 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
This applies to the 2nd Generation Camry but the concept should still be the same for yours.
http://members.tripod.com/~importmania/howto/howto.htm
1991 Toyota Camry DX: Mods listed on Cardomain
http://www.cardomain.com/id/whitecamrydx
91camryDX is offline   Reply With Quote
Old 09-22-2002, 09:04 AM   #4 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
yeah, AFAIK camrys (at least gen3 and gen4) use shifter cables instead of shift linkage.
ratko.org
Ratko is offline   Reply With Quote
Old 09-22-2002, 10:18 AM   #5 (permalink)
OK so does anyone know if the Gen2 5sp uses shift linkage. How hard would it to check?
Thanks for the link Lemon Tree I was planning on doing that when I buy a new boot and knob but I also want to shorten the actual throw distance, not just the length of the shift lever.
Old 09-22-2002, 08:39 PM   #6 (permalink)
Ok this WILL NOT work for Camry Transmissions
http://www.imagestation.com/album/?id=4291332973&idx=1
There I have an exploded view of the Shifting assembly for Gen2 tranmissions. It uses cables. I think though that by shortening the length of the selecting ballcrank shortened shifts could be acheived. Any ideas?
Old 09-23-2002, 06:22 AM   #7 (permalink)
it was all a dream
Use a torch and move the pivot ball of the shift lever higher. This has been done.
Just make sure the bottom of the shifter still clears the bottom, but you could use washers to remedy this.
latez.
ratko.org
