You should really do searches before posting questions. Other wise your gonna have to pull out the from trim peice. It's actually quite easy to get the front of our dashes apart. The bulb you cannot pick up from any auto parts store. It's a toyota only made part. The bulb and wired into a flat base. Your gonna have to go to the junkyard and grab a bulb out of a another gear. Oh, by the way, the d bulb is contained in a small module that snaps into the main cluster. You have to squeeze three tabs and gently pull it out. Then use a small flat head screw driver to remove the bulb. I'm sure there is picture somewhere on this forum.
Totally stock 00' 4cyl in Sage. Looking for set of nice stock 15" alloys for cheap, got any?
