dealership fuel filter change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2005, 12:02 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
3rd Generation dealership fuel filter change
so my mechanic called and said that my fuel filter line? is all mangled and if he tries to change it, there is a risk of messing it up which would make big problems. i was wondering if toyota would take on the responsibility of changing that? and if so, do you know how much it could be?
MrSo0h0o is offline   Reply With Quote
Old 07-30-2005, 03:17 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
your machinic prolly screwed it up and then trying then telling you it was screwed up. the biggest thing with gen 3's are that the bottom nut on the fuel filter is on crazy tight. you need to use a set of box end wrenches. your machinc prolly striped the nut, and if you take it to toyota there going to tell you that YOU screwed it up and it will become an expensive job.
your now cheapest solution is to tear the line out and get a new one from the junk yard or cut the line and slice a new one in.
^ and leaving it that way!
Old 07-30-2005, 11:09 PM   #3 (permalink)
MrSo0h0o's Avatar
no this is a trusted mechanic. its a used car so probably the person before or possibly i did that :-/. gonna take it to the dealership soon though.
Old 07-31-2005, 04:49 PM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
The nut could just be rusted to the line. Happens all the time in the northern states where they dump all that salt on the roads in the winter. Sometimes they break loose, sometimes they dont. Just make sure to put some anti-sieze compound on the fitting of the new line. Happens all the time with brake lines too.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
