Power Steering Pump-Belt Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2005, 02:15 PM   #1 (permalink)
View Nowhere Man's Photo Gallery
First off I have a 94 Camry V6 LE, 1MZ-FE. And for the life of me I cant get the power steering belt off. I've loosened the pivot bolt on the bracket (see picture below), but its still not moving. So what am I missing, is there some other bolt that has to be loosened?
(loosened pivot bolt, large bolt near the middle of the screen)
Cheers,
Brian
Nowhere Man is offline   Reply With Quote
Old 07-31-2005, 04:15 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Loosen up the upper bolt too.
http://www.autozone.com/servlet/UiBr...3d8013f7b8.jsp
"Skoolin' the unlearned!"
Old 07-31-2005, 02:57 PM   #3 (permalink)
Thank you, I took off the entire bracket and that did it. At first it seemed stuck in place, but then I just decided to pull really hard on the belt and that finally moved the pump so I could get the belt off.
Cheers,
Brian
