Originally Posted by 96CamryDX
ok i love my car but, everytime i catch a side view of it i hate it!!!!!...the annoying rake(back higher than front) of all gen 3s..So i thought of just putting lowering springs in the back ...i did some measurements and 1.5 inch lowering springs would work best for it to be level....well what do u guys think...would this be hard on the overall suspension system...and if i get enough funds i might put tokicos in the back with the lowering springs...i dunno how do u guys feel
You just have to make sure that when you measure out how much drop you want, you take into account how much the springs will/might settle, or else you'll end up with a car that's got a lower back end, and if you ask me, that's even uglier.....
and what soundlzrd said is true....if you just upgrade all your springs, the car should even out...with a possibility that the end will be lower....but then just remove your spare from the back, and the end should lift back up to be about even.....or at least if does with my ebaich's w/ stock struts...
and for real, if you want to consider performance, the front springs are more importanat than the back ones.....the front prevent you from diving into corners as much....
good luck... 8)
