for the short term....try running on vented air..full blast and spray lysol into the outside vents
what do you ususally do when you operate your AC?
you could try on your trips when you are almost home or to your destination, to switch from circulating air to vented air so moisture has time to evaporate.
Are your drains plugged? if it's plugged and moisture from the AC has no where to go, you might get that smell too.
Try these before you go through the hassle of getting to your filter
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
