Ok, I just finished mounting a set of blue Cathodes under each on of my front seats. How do I wire them so that they come on when the doors open, but I can also turn them on/off if the doors are closed, basically the way that teh stock dome light works.
Reason: update
+ dome light circuit. to 3 way switch, to relay to CCFL circuit (dome pos)
+ 12V, to 3 way switch, to relay, to CCFL circuit (on pos)
and the off pos, needless to say, not connected
that's what i'd do, about right ?
94' 2.2 Camry
- -fast enough to get tickets-
jaguar answered that one peerfectly. Personally you can run it with the parking lights as well.....maybe a better choice for switching the leads to....it's your call
Jaguar: Thank you very much. I know it may be asking alot, but do you think it'd be possible for you to do a little diagram in paint or something...I am very good with mechanical things, but for some reason, wiring kicks my ass.
Thanks alot guys, now all i need to do is go buy a relay and switch. That is a normal on/off switch right? Not the 3-way kind suggested before? And in that diagram, is there any thing going to the switch besides the ground and the "85" terminal of the relay. And I put the power to both the 86 and 87 terminal?
Yup.
Use a SPST (2 prong) switch. Or a SPDT (3 prong) switch.
SPDT comes in 2 styles:
1. on-on
2. on-off-on
You want the on-on. Use the center connection and one of the outer connections.
No.
Yes.
85 and 86 are for the coil inside the relay. One side must be connected to positive and the other side to negative. Since 85 is connected to ground. 86 is connected to positive.
When the coil (85 and 86) is powered, 30 is connected (switches) to 87.
Door trigger wire is a negative trigger. In other words it outputs ground whenever any door is open.
Switch is there so you can manually trigger the relay when all the doors are closed. The switch supplies ground to pin 85 of the relay.
Well, I finally had time to wire my lights. Thanks for all the help guys. The only issue is that when I turn the lights on with the switch, the open door light on the dash comes on along with the ring around the ignition switch. That makes perfect sense, but I don't really want to add another switch just to fix that...Here's some pictures:
and here's some shots of the trunk:
then just the car with the doors/trunk open
thanks guys
nice...lol...horrible first two pictures..i coun't make them out, thought they were jsut more pics of your trunk.
Good job man
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
