wierd warning light problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2005, 05:47 AM   #1 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
3rd Generation wierd warning light problem
The warning light on the temp gauge that indicates there is a burned out light somewhere on the car is being funky. When I push down on the brake pedal, not immediately, but after about 10seconds of holding the pedal down that warning light comes on. I parked the car in the driveway and weighted the pedal down with the ever high-tech brick and went around the car when the light came on. All of the lights, inside and out, were working perfectly . Does anybody know what is wrong???
Will
HoboJoe is offline   Reply With Quote
Old 08-01-2005, 08:59 AM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
You may have one that is about to go out but hasnt yet, you cold have a rpoblem with teh sensor. or you could have a bad ground. OD any of the lights seem to not be as bright as the others. If so replace that one and try it again. I cant rememerb how you can test the sensor but here is a way. Then you can check all the grounds on the tail lights themselves. Just a couple of things you can try out for now.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 08-01-2005, 08:59 AM   #3 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
Will
probably a tail light......fuckers can be tempermental...use dialectric grease too...the cure all
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 08-01-2005, 10:03 AM   #4 (permalink)
tC
View 95camguy's Photo Gallery
have you checked the 3rd brake light bulb. my 95 was doing the same thing you stated and then one day my friend noticed that my 3rd brake light was not working one day when he was driving behind me,
i know it seems obvious but i missed it for months. then i replaced the bulb and all is well.
hope this helps
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 08-01-2005, 10:15 AM   #5 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
possible that one of the fuse is about to go out
skewe is offline   Reply With Quote
Old 10-11-2005, 12:37 PM   #6 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
I did a search on this subject before making a new thread. Good thing I searched, because this same problem has arrose on my car in the last few weeks.
Exact same symptoms. The 'bulb-out' warning light only comes on after I press the break pedal. It doesn't come on immidiately, but rather after about 3-5 seconds of holding it down.
All lights are functional.
I just wanted to check on TN before I started doing current-on and current-off continuity tests on the associated lighting circuits within the car.
So before I get my hands dirty tonight, anyone have had this problem? Got any quick fix's that haven't been mentioned in this thread yet?
Keep is offline   Reply With Quote
Old 10-11-2005, 03:13 PM   #7 (permalink)
View Brujo's Photo Gallery
There is a known problem with Gen 3s and the wiring that goes into the trunk. I believe the problem arises when a wire gets stripped down because of the opening and closing of the trunk or the wire gets pinched and it touches the metal causing a ground. Search for older threads since this has been discussed many times before.
Got CAI? Check out my custom CAI! Click here
Brujo is offline   Reply With Quote
Old 10-11-2005, 04:41 PM   #8 (permalink)
Mr. DSM
Keep's Avatar
Thanks, Brujo.
I've already searched this subject, but decided to post in this revived thread.
I will look for chaffed wires in the trunk area, before I start my diagnostic routine.
Old 10-11-2005, 07:05 PM   #9 (permalink)
1993 Camry XLE
HoboJoe's Avatar
I can't get the clips off the trunk lining to get to the wires, just enough to get to the tail lights. Is there some kind of tool that can get those little bastards off? The screw driver took forever and made it so the clips wouldn't go back in.
Old 10-11-2005, 07:16 PM   #10 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $912627
iTrader Score: 59 reviews
Third Brake Light! Replace that first. That may save ya alot of time!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 10-12-2005, 09:44 AM   #11 (permalink)
Mr. DSM
Keep's Avatar
Well here's the update.
The culprit was the passenger side brake light.
It is an 1157 bulb (2 fillament) and both filaments were fine.
The problem was that the brighter filament's positive contact point was slithly oxidized on the surface of the metal. Therefore it was an intermittant 'open' in the circuit.
I used some emery cloth to shine up the contact points, and used a little dielectric grease.
Everything is fine, back to normal.
While I had the carpet pulled I decided to shine up and dielectric all of the bulbs in the rear as preventative maintenance for this winter. I'm glad it was something easy to find/diagnose. Normaly electrical problems are a PITA
Old 10-12-2005, 01:24 PM   #12 (permalink)
Super Moderator
eyeball96's Avatar
Glad you got it fixed, guess I was wrong!
98 Honda CRV
08 GMC Crew
Old 10-12-2005, 03:48 PM   #13 (permalink)
Mr. DSM
Keep's Avatar
I still took your advice
The third break light was the first thing I checked!
That is probably a common fault, it just didn't happen to be that fault THIS time
Thanks for the replies nonetheless
Old 10-12-2005, 05:36 PM   #14 (permalink)
Super Moderator
eyeball96's Avatar
Your Welcome! Thanks for the acknowledgement!
98 Honda CRV
08 GMC Crew
