fixed my power problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2005, 07:30 PM   #1 (permalink)
The Other White Meat
terrastrife's Avatar
a couple of weeks ago i aske for help in relation to my power problems... weak acceleration, droppign revs etc, plenty of helpful suggestion, i did all i could.. check for vacuum leaks, checked plugs and leads, clean tbody n stuff.
it ende dup being an exhasut leak that happened quite randomly (and ya couldnt hear it either).. i had the bolts all tightneed up again yesterday and everything seems to be good.. for now...
terrastrife is offline   Reply With Quote
Old 08-01-2005, 07:51 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Where was the exhaust leak? By the manifold?
Silver Streak is offline   Reply With Quote
Old 08-01-2005, 08:11 PM   #3 (permalink)
between the manifold and y pipe. my y pipe takes a lot of damage and i guess it dislodged itself every now and then
edit: THESE WERE LOOSE
THESE are the only points which hang my exhaust (not counting head-manifold connection wher eit starts.
you can see the battle damage wher eit hits the ground.
