hood latch adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2005, 08:44 PM   #1 (permalink)
iTrader Score: 6 reviews
View Trdkamuri510's Photo Gallery
how do u adjust this loweR??? my hood is a bit loose and i cant really adjust it since its c/f
sittin pretty wid a lil wide ass
Trdkamuri510 is offline   Reply With Quote
Old 08-01-2005, 09:23 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
bonnet clips you could unbolt it, drill the bolt holes taller (obling/oval ish) so that it can be bolted back on a tad lower...
is the bonnet line even with the fenders or what though. you might nee dadjusting of the hook itself (like jb welding it or something.)
terrastrife is offline   Reply With Quote
Old 08-02-2005, 09:39 AM   #3 (permalink)
imtrying to avoid drilling holes in it till i dispute and possibly get a replacement hood.. the hood latch is just a bit short so i get a bit of a popping.. ill put in hood pins as a last resort as i already got some sitting in my garage...
Old 08-02-2005, 09:43 AM   #4 (permalink)
the2 bolts that hold the mechanisom down... drill their holds more obling so you cant shift it up and down slightly
Old 08-02-2005, 10:04 AM   #5 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
loosen the 2 10mm bolts on the side and the assembly should slide down, then turn the bumpstops down as well
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 08-02-2005, 09:06 PM   #6 (permalink)
hrmm there are three holding it on.. one behind the actual assembly that cant be seen. i guess toyota designed it to be non adjustable....fook... there is also a bar running down it.. going to take it to my friend to see if we can do anything bout it at all..
until then hood is off ohh well.
