Gear oil or ATF? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2005, 10:05 AM   #1 (permalink)
View charles_summers's Photo Gallery
2nd Generation Gear oil or ATF?
I have just bought a 1991 Camry with 5-speed manual and 2.0L 4-cylinder engine. (248,000 miles and still counting). My Haynes book says to use ATF in the transmission. My local auto parts says their book shows gear oil. I could not find a definitive answer by searching the forums, so I'll ask here if anyone has the right answer--Gearlube or ATF? Thanks.
charles_summers is offline   Reply With Quote
Old 08-02-2005, 10:16 AM   #2 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
The compter system toyota uses comes up as follows:
First Choice = 75W90
If unnavailable, use = 80W90
then = Dextron 3
then = Dextron 2
Use 75W90 Gear oil
I find it weird that it even shows ATF on the system, as a LAST DITCH resort, weird.
Keep is offline   Reply With Quote
Old 08-02-2005, 11:42 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308675
The manual stated Dexron II ATF for the 4-cylinder 5-speed. People have had good luck with both GM Syncromesh and gear oil...
-Charlie
Old 08-02-2005, 12:04 PM   #4 (permalink)
Mr. DSM
Keep's Avatar
Syncromesh is amazing
so is BG syncroshift
Old 08-14-2005, 09:32 AM   #5 (permalink)
97 Camry
View Davee's Photo Gallery
My problem is cold weather cold engine transmission stiffness -- Any help here for that?
Davee is offline   Reply With Quote
Old 08-14-2005, 11:02 AM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $912627
iTrader Score: 59 reviews
I had a shop put 90wt gear oil in my 88 corolla I had then. F'd it up bad, couldn't hardly shift gears, took it right back they put in ATF (recommended) I could shift again but the car was never right after that!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-14-2005, 12:16 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
dexron
