I bought the ones for the '97-'03 Camry thinking they would be the same for '05. NOT! Ordered the ones for the '04 Solara and they fit. Got some extra drop due to the Camry being a heavier car. The '04-'05 springs have a tapered coil on the bottom so the lower spring seats are different. Go here and look for the '03 Camry TRD spring to see the pics. It shows the right pic.
http://www.trdparts4u.com/
Go here and you'll see the spring for the '04-'05 Solara/Camry on the front page.
http://www.trdusa.com/
Edit - They removed the pic at TRD USA. Go to
www.trdsource.com and look up the '04 Solara TRD spring and they'll show the correct springs. Bascially there are 2 types of springs for the Gen 5 Camry. Check your springs before ordering to make sure you get the correct ones. All you have to do is jack the car up and look at the spring to see if you have the taper on the lower coils.
