ECU Replacement..will it fit?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2005, 12:48 AM   #1 (permalink)
vL
92Camry5sp's Avatar
Gameroom cash: $221105
iTrader Score: 6 reviews
View 92Camry5sp's Photo Gallery
I've search on this, but didnt seem to find anything..well, a little but not what i was looking for..i was wondering if the 91-^ MR2 NA ecu fits 92 camry 5sFE..I wanted a higher rev on the RPM..RedLine starts at 6300 isnt enough for me..i want somewhere around 7 to 7500..I know this might sound rediculous..but i just wanna see if i will gain any performance on this..Let me know...Thanks..
92Camry5sp is offline   Reply With Quote
Old 08-03-2005, 12:54 AM   #2 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
comon really, remember u have a 5sfe.....its not a racing engine, it would never beable to handle that high RPM w/o some serious modifications to the internals,,,even if somehow u could get it to that through ecu. Besides just because u can get higher RPMs, wont make it go faster, with taht engine id probably get slower, ur power band would die in the mid to high 5g range anyway
ag6286 is offline   Reply With Quote
Old 08-03-2005, 12:54 AM   #3 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
Just to sum up what you'll be flamed with earlier:
-There is no power beyond redline on a stock motor.
Other than performance, is there any other reason you want to get up 7K?
Lord_Anarchy is offline   Reply With Quote
Old 08-03-2005, 12:58 AM   #4 (permalink)
vL
92Camry5sp's Avatar
I know its not a racing engine..Just wanted to be a tricked out engine..having a camry revving up at 7 to 7500 RPM sounds nice..and Lord_Anarchy other than performance, i just want to be different from other people who have there redline start out at 6300..But backto the topic..will the hardness fit perfectly or do i have to do some modification??
Old 08-03-2005, 04:25 AM   #5 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
have you done any engine mods to justify raising the redline? Otherwise your "tricked out" engine will be much the worse for wear. Those redlines are there for a reason.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 08-03-2005, 04:38 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Theres no reason for the motor to rev that high.
1. Its not designed to rev that high.
2. Even if you could rev it to 7,000 - 7,500 rpm, the motor is not going to make anymore power.
3. 5S-FE makes peak torque @ 4,400 rpm.
Till you build the motor (block & cylinder head), theres no reason for you to raise the rev limit.
Save up and do a 3S-GTE swap. That motor will rev to 7,000 no prob.
"Skoolin' the unlearned!"
Old 08-03-2005, 10:35 AM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Let me get this straight..
No engine mods to support a higher redline...
No power to be made past stock redline...
You want to be different so you want to rev. to past 7k?
And that makes the motor "tricked out"?
I'm actually laughing out loud right now.
Old 08-03-2005, 10:40 AM   #8 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
The only time I hit above the redline is at 135+ mph......but that is with a V6.....your 5sfe won't do that unless it has HEAVY mods (like forced, N20, SC...etc)
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 08-03-2005, 11:12 AM   #9 (permalink)
Gameroom cash: $147537
Since when the MR2 got a high reving 5S-FE?
If you drive manual, just shift high. If you drive auto, never mind.
Also the 5S-FE is a stroker engine which will never able to rev high.
Old 08-03-2005, 01:00 PM   #10 (permalink)
The Other White Meat
terrastrife's Avatar
I HAVE THE SOLUTION
get new tacho trim with NO RED LINE
so it goes all the way to 9000rpm with no RED LINE youll still hit the CUT OUT at around 6800-7000RPM though
terrastrife is offline   Reply With Quote
Old 08-03-2005, 10:04 PM   #11 (permalink)
vL
92Camry5sp's Avatar
I was just trying to see if it fits..i didnt ask for any information if it'll rev that high..i've seen Honda's using acura's ecu..thats why i ask if the mr2 with fit in the camry..and mr2 does have a higher rev on the rpm..
Old 08-04-2005, 01:07 AM   #12 (permalink)
5SFE
Hondas using Acura ECUs? Well.. if they had a B series swap from the ITR or Integ, it's a given. You are saying that they do this, ECU transplanting, on stock D series motors and what not?
Old 08-04-2005, 01:19 AM   #13 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
3rd Generation
I like terrastrife's idea with the no red line tach. Hell, get it and paint the red line at 7000rpm. Not to mention, it won't KILL Your engine!!!
HoboJoe is offline   Reply With Quote
Old 08-04-2005, 01:31 AM   #14 (permalink)
5SFE
In the end, that's probably the end all for this thread. The stock 5SFE block will not make more power and raising redline would defintely wear it out, assuming it could mechanically, at stock, reliably go up to 7-7500K every time.
But, if this doesn't deter you, then.. can't simply killing the Rev limiter solve the redline issue?
Old 08-04-2005, 01:45 AM   #15 (permalink)
vL
92Camry5sp's Avatar
The gsR ecu will fit in a 92-95 civic si d series motor..But you guys just dont get the question..im not asking if it will ruin the motor or not..Im asking IF IT WILL FIT OR NOT..If i blew the motor..Im using my money to get a new one..not yours..So If you want to make some comment or opinion..make a new thread..And yet after all of these REPLIES..No one hasnt answer the question..Just say yes or no or i need a universal harness..Thats all i need to know..
