Where can i get an air/fuel ratio sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2002, 03:11 PM   #1 (permalink)
View sabbates's Photo Gallery
Where can i get an air/fuel ratio sensor for my 99 Camry 4 cyl?
The dealer wants $280. That sounds a bit high.
Any suggestions?
Thanks
sabbates is offline   Reply With Quote
Old 09-25-2002, 04:09 PM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700865
iTrader Score: 6 reviews
View EKam's Photo Gallery
try:
http://www.nordskogperformance.com/airfuel.html
http://www.autometer.com
You can also find these in ebay.com or nopi.com
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 09-25-2002, 04:38 PM   #3 (permalink)
View Deep's Photo Gallery
Do you mean O2 sensor?
Deep is offline   Reply With Quote
Old 09-25-2002, 04:50 PM   #4 (permalink)
Thanks, but the part I'm looking for is not an add-on. It looks exactly like an oxygen sensor, but it puts out a different voltage range.
I haven't been able to find an aftermarket part that is compatable.
Old 09-25-2002, 05:39 PM   #5 (permalink)
EKam's Avatar
You mean a 4 wire o2 sensor?? knock sensor??? You have got to be more specific... :-?
Old 09-25-2002, 06:22 PM   #6 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Heis talking about an air/fuel ratio sensor. It replaces the o2 sensor. The air/fuel sensor's voltage mid range is about 3.3V where as the O2 sensor voltage mid range is .450 mv. On newer cars they have an air/fuel sensor on the manifold and an O2 sensor after the cat.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
