Will 19" Wheels fit an '05??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2005, 12:30 AM   #1 (permalink)
View notstock4long's Photo Gallery
Gen5 Will 19" Wheels fit an '05???
I get my car back sometime this weekend hopefully, fro mthe body shop. I want to get some new wheels for it soon after, but I'm not sure what will fit. I have a set of 19" wheels for my '94 Formula that I don't need, and I'm hoping to use the tires from them.
I believe the tires are 245/40/19. Will this fit on an '05 Camry? I don't mind if it rubs a little on real sharp turns or something, but will they even fit?
And also, what is the factory offset? The wheels I am looking at have a +47mm offset, and I think the factory offset is 45, correct?
Thanks for any help guys!
notstock4long is offline   Reply With Quote
Old 08-04-2005, 01:01 AM   #2 (permalink)
View majorgercko1's Photo Gallery
I am sure that 19s fit. THat is the max i believe without having to change the strut bar. The tire would have to be really thin though, i suggest getting 18s so that you have a suatable ride.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 08-04-2005, 01:14 AM   #3 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Watch majorgercko1. One of these days, you will know how we feel when the same topic is brought up by a new member 2-5 times a day.
And you my good tomadachi. Rubbing is a What would happen to you if your tires happen to pop because of the rubbing while turning?
Basically the offset for a 19" rim on a camry will be 19x8 at max.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 08-04-2005, 01:26 AM   #4 (permalink)
Well, i want to get my posts up so i dont mind HAHA
Old 08-04-2005, 06:46 AM   #5 (permalink)
Cool, so I can do it with a 19X8" wheel huh? And what about with 40 series tires on it?
Old 08-04-2005, 08:55 AM   #6 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
yes
they will fit
search for gen 5 or rims
skewe is offline   Reply With Quote
Old 08-04-2005, 08:55 AM   #7 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
View white3ch0c0late's Photo Gallery
Uh, you should check the bolt pattern. If the pattern isn't 5x114.3, it WILL NOT fit. If you're getting 40 profile tires, you're going to rub. You need 35 profile tires.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 08-04-2005, 09:40 AM   #8 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
im running with 19 x 8.5. they dont rub at all. the tires are 215/35/19 tires. u suggest u use a 225/40/19 tires. my rims are almost on the floor cuase the tires are to small o well. on the newer camrys u can probably fit 20's without a problem cuase there much bigger then the older camry's....
lucanhookup is offline   Reply With Quote
