stooper - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2005, 08:25 PM   #1 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
2nd Generation stooper
I just ran into a roadblock, I am getting my parts rounded up for my 3sge-e153 swap and found out that the v6 passenger intermediate shaft has a bracket that bolts to the block of a v6, I know i have to use this v6 shaft in order for the e153 to work so what do I do since it wont bolt to my 3sge and the bracket that will bolt to my 3sge is way too small?
Old 08-06-2005, 08:43 PM   #2 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Are you saying that you some one forced you to take your parts off your car? I don't really understand what you are you talking about.
V6LE_CAMRY is offline   Reply With Quote
Old 08-06-2005, 08:46 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
in other words the e153 trans takes the v6 axles, but i am mating it to my 3sge, so i need a bracket for the v6 shaft that will bolt to my 3sge
Old 08-06-2005, 09:22 PM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I think your talking about the hub carrier bearing.
I thought all block's had similar brackets...well..at least the 3sge.
Have you actually compared the two?
If there different, you might have to make up an adpator plate of some sort.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 08-06-2005, 09:28 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
the 2 are completely different
Old 08-07-2005, 12:38 AM   #6 (permalink)
V6LE_CAMRY's Avatar
You should ask 88LE he should know
Old 08-08-2005, 03:50 AM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308675
MR2 carrier...
-Charlie
