IPOD auxilary input - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2005, 06:58 PM   #1 (permalink)
View dkbavaria's Photo Gallery
IPOD auxilary input
hey all
I want to connect my ipod to my 2002 camry.
I dont want to use an fm modulator or fm transmitter
how can i do this
also in my camry model, the tape with the wire thing wont work. it also doesnt work in my cousins camry. so i guess its all camrys.
whats my cheapest option
thanks
Drew
dkbavaria is offline   Reply With Quote
Old 08-08-2005, 07:09 PM   #2 (permalink)
View rwjcpa's Photo Gallery
This will work
http://www.cardomain.com/item/USSPA11TOY
I have been looking at this for a while. The only drawback is that you can't use your playlists. You have to set up five new playlists called TOYOTA1, TOYOTA2, etc. If it didn't limit you to five playlists it would be perfect, since you can still use the steering wheel audio controls if you have them. Also, it costs $100, but that is way cheaper than some of the other ones out there.
rwjcpa is offline   Reply With Quote
Old 08-08-2005, 07:38 PM   #3 (permalink)
t^3
Formerly Mad Scientist
View t^3's Photo Gallery
The cassette adapter should work, but as you probably know, an aux input sounds the best. Search for something called TOY-AUX. They sell for around $60. It plugs into the CD changer port in the back of your stock headunit, but it is just a straight CD changer port to RCA converter, and then you'll have to get a separate RCA to 3.5 mm adapter. No controls, no playlists, etc. This is the cheapest aux input option for your stock headunit.
t^3 is offline   Reply With Quote
Old 09-01-2005, 03:37 AM   #4 (permalink)
I dont have a cd changer controls
I am thinking of buying the P.I.E. TOY-AUX, but my car factory stero doesnt have cd-changer controls, will this work with my car?
thanks
Dhruv
Old 09-01-2005, 11:45 AM   #5 (permalink)
t^3
If you have the standard, non-JBL factory sound system, you do have the CD changer controls. You don't have anything hooked up to it so nothing shows up. Once you hook up the TOY-AUX, you just press the CD button to switch to the CD changer, in this case, the TOY-AUX connection. If pressing the CD button plays your CD, press it again.
Old 09-01-2005, 05:19 PM   #6 (permalink)
2005 Camry XLE V6
View 05CamryGuy's Photo Gallery
Does the JBL factory sound system have a useable AUX connection? I'd like to connect my mp3 player to that too
2012 Lexus RX350 Luxury Pkg w/Nav + HUD, ML & PA
2010 Lexus IS250 AWD w/Nav
2007 Lexus ES350 Ultra Luxury w/Nav, ML & PA
2007 Camry XLE V6
2005 Camry XLE V6
05CamryGuy is offline   Reply With Quote
Old 09-01-2005, 07:26 PM   #7 (permalink)
View ToyTrains's Photo Gallery
I have a 2005 Camry LE, with the JBL tape/CD player (no XM). It does have the CD changer controls. Actually, I just hooked up the adapter on mine tonight. It's the bomb. My XM receiver and MP3 player sound so much better than through the tape adapter.
My Camry is blue-ish
ToyTrains is offline   Reply With Quote
Old 09-01-2005, 08:03 PM   #8 (permalink)
View ModPod's Photo Gallery
http://www.cartv.com/content/researc..._Tip/pagenum/1 has a video of a direct connect adapter being installed. I have them same one and I <3 it.
ModPod is offline   Reply With Quote
Old 09-01-2005, 09:49 PM   #9 (permalink)
t^3
Make sure you guys get the right adapter for your Camry. The 2005's and newer have a different plug, and I believe that the steering wheel control plugs into that newer CD changer port. The adapter should have a spliced connection where you can plug your steering wheel control plug into that.
Old 09-03-2005, 06:04 PM   #10 (permalink)
Gen5 Worked fine for me
I have a 2005 Camry LE and the adapter installed with no issues at all. It came with a short extension/adapter cable in addition to the main cable. I used this short one to match the plug on my head unit. I didn't have to unplug anything.
Old 09-20-2005, 06:17 PM   #11 (permalink)
Good point - I would check it out myself or ask to make sure you do not need the additional adapter.
Old 10-10-2005, 03:58 AM   #12 (permalink)
View schnoid's Photo Gallery
Thanks for the suggestions. I have a 2002 Toyota Camry with Nav System. The Nav System is a screen in front of a single CD player with tape deck. All mention of people installing these adaptors seems to be talking about plugging it into a CD changer. Does this mean it won't work on my car? Thanks
My 2002 Camry XLE V6
schnoid is offline   Reply With Quote
Old 10-18-2005, 03:12 PM   #13 (permalink)
View nockamura's Photo Gallery
Hey, I have the USA Spec iPod integration in my '05 Camry, but I was having some problems with the unit (specifically charging issues). If any of you have the USA Spec please let me know if you have had any problems with it.
nockamura is offline   Reply With Quote
Old 10-18-2005, 03:22 PM   #14 (permalink)
Fresh 2 Death
View acs72727's Photo Gallery
read my DIY it should be the same justof course u have a diff model
DIY ipod integration
07 4runner Sport Edition
acs72727 is offline   Reply With Quote
Old 05-23-2008, 08:50 AM   #15 (permalink)
View upinya's Photo Gallery
Originally Posted by dkbavaria View Post
hey all
how can i do this
thanks
Drew
Yesterday I successfully installed the Peripheral Electronics Asian/Import iPod Interface in my 2002 Camry. The item was purchased through Crutchfield here:
http://www.crutchfield.com/App/Produ...=detailed_info
The stock radio has the faceplate #AD6806.
So for all of you interested, this solution does in fact work
upinya is offline   Reply With Quote
